This is what one guy on the prius forum said.
I believe these numbers. |
Re: Hubcaps?
I'd like to know what you did for centering, length of screws, etc. I'm sure I can find the pizza pans :) |
Once they arrive, I expect I'll probably have to drill a small hole in them, so that I can have access to my valve stem (especially the visual marker I have on my stem, that lets me know when my air pressure is low). And I imagine they might stay on better, if I paint a little paint on rubber (which is easy to buy in a hardware store for a few bucks a small bottle) on the spring loaded teeth that hold them in place. But otherwise, I expect them to be pretty easy to put on. And I'll even get back some of the extra hubcap weight, as I intend to remove the existing OEM "center caps" from the wheel, before installing these new hubcaps. So the only "extra weight" will be the difference in weight between the new hubcaps, and the wheel center caps I'll be removing! BTW: The forum post about the Prius owner (that someone else linked to in this thread) probably does put smooth hubcaps in perspective (as an aerodynamic mod). After all, around 1 MPG for a 50+ MPG car, is around a 2% gain from the hubcaps. i.e. enough to be "worth while", but small enough that it would be easy to miss the benefit unless you already have a high MPG car. And I wouldn't be surprised at all if that number is about right. However, either way, I suspect my car will look a little nicer with the hubcaps on, even if I don't get a (small but) noticeable FE boost. |
Found a great article on do-it-yourself moons!
Main site is https://www.vfaq.net/ Actual article is here: https://www.vfaq.net/mods/Hubcaps.html Very neat application of pizza pans! Think I might try this myself! |
OdieTurbo -
CarloSW2 |
I'd drill & tap alloys to put smooth covers on - if I had alloys.
If only my VX rims had fit my Firefly. If only.... https://images6.theimagehosting.com/a...vx-rims.th.jpg (Photoshop job) Alloys sure look nice, but I'd still cover them up. |
MetroMPG -
CarloSW2 |
