run flats aren't that heavy cause you can only get self-supporting-sidewall runflats in low-profile sizes. maybe 20% heavier than a normal tire the same size but still lighter than a 60-70 sidewall. definitely NOT enough to be a loss. I'll weigh mine when I move tires around later this spring.
fix-a-flat and an inflator pack only work if it's a small puncture that would have been losing air for a long time. those and repair kits also assume that you notice it before the sidewall gives out and that that's the only problem. IE things that would be prevented by periodic checks. fix-a-flat might get you off the road a little ways in a pinch for a larger hole. as for removing the spare because people never check them.... people aren't really the issue. do YOU check it even once a year? I work in a shop that does a lot of tires and I see them come in all the time at 20, 30, 40 etc psi. is it good...no but it works. and that's a 10 year old spare that's never been checked that only lost 20-30 psi and is still drivable. once a year oughta keep it at least 50 psi. |
Wouldn't run-flats have a lot of rolling resistance, though?
I have had several instances where I almost needed the spare. One time I plugged a tire that picked up a nail without even taking it off and aired it up on the spot and continued my drive home. Another time I got a puncture and couldn't find it and stopped 2x on the way home and just pumped it up and kept going and made it home without useing the spare. (I carry a compressor and a home made tire plug kit) I wouldn't go without a spare and jack ever. Unless you plan on having a flat at 12:00 high noon right in front of a big wholesale tire place that has a clearance sale on the exact same size and brand tire you are running so they can match it up if they can't plug it. Just my opinion and experience. |
also carry a foot square of 3/4" plywood as in the summer the asphalt can get hot enough that the little 4x6 inch square the jack base is can sink into the pavement... happened to my dad back in the 70's with one of those pole jacks:D |
this thread is getting too long. someone needs to create a poll and be done w/ posts!
I have had two cases of puncture in the past. Each time, I used the jack and the hand tools to put a spare tire on. Now I will not drive without them.
A square of plywood is a very good idea. My sister once called me. She was driving her husband's pickup when she got a hole in a tire. I drove out to help her, the flat was on the left side of the truck, and she was on the left side of the road in the median strip. The jack kept squishing down into the soft dirt. I had to wait until traffic cleared, and I drove the truck to the opposite shoulder of the highway so I could place the jack on the shoulder of the road instead of in the grass.
