Also why we run 86 octane fuel instead of 87 like they have at the coast.
Everything I read points to us supposedly having better mileage up here but it doesn't happen. On the motorcycle i do though, it tops out about 75-80 (top speed doesn't change with altitude, just how fast you get to it does) and at seal level it gets about 60mpg at those speeds while up here i'm getting around 70-75 mpg. |
Another thing to consider at high altitude... The air is less dense so in theory your areo drag should be less...
-Jay |
jeep45238,
you can see the IAT reading via your scangauge. as for the arguement about the altitude. I understand the theory that you are using but obviously there are more affects to high altitude than just thinner air. my drive is 20 miles one way (40 per day) also of note is that my instantaneous MPG were lower before the WAI. I can't explain the altitude arguement but with the WAI you are just changing one variable, not the entire environment of the car. |
Beef - I'm aware I can see the IAT reading - but that sensor is about 8 inches away from ambient air, right behind the headlight - and the air has to go through about 2.5 feet worth of black plastic that's heated by an engine bay for a whole drive. That's my only point - without relocating it toward the throttle body, it's not accurate - the air is warmer than where the IAT is, but by how much is unknown.
my incoming air moves pretty fast, I don't think you can heat soak air but so much. in the same respect, I run my air along side my header for the heat which is much hotter than the IAT is saying that it is. the air comes by the header so fast that the temp difference has to be substantial to get the air to increase in temp enough to matter.
good luck to you in your choice but a lot of saturn guys on here have seen pretty good gains from a WAI. that is your choice. also, you know that it isn't that hard to relocate. if you care that much |
It is possible that GM took that into account and the sensor or the way the ecu reads it is offset from the factory to compensate for that.
Beef,
I've already said I'm going to do it. Remove the airbox silencer, enlarge the hole a small amount, toss in a piece of exhaust flex pipe, it's done on that front. I'd solder in a wire extension for the IAT to relocate the sensor at the throttle body. Yes, I am that finiky. |
one more thing, if you are planning on doing it, you may want to fabricate some sort of heat shield to go between the front of the car and the header. I have a pic in my garage. you can't see my IAT sensor in the pic but it is just in front of the throttle body (also not in the pic).
I used metal flasing from lowes to do this. on a side note: how did this spam thread turn into a full blown discussion about the WAI vs CAI. I think we have already had this arguement too many times in the past. |
It wasn't an argument - just saying in theory both can give better mileage, but that warm air gives bigger gains. :confused: |
