GasSavers_Hal9000 |
09-26-2008 02:48 PM |
Originally Posted by theholycow
(Post 119621)
That heat-scavenging effect maybe also increases efficiency after warmup -- instead of discarding that heat energy, it's put back into the engine. Additionally, the warmer air may enhance fuel vaporization.
There could also be other factors at work for your high-altitude observations -- for example, the lower pressure air outside the engine would increase pumping losses effectively nullifying the WAI's density advantage. Hills could cause you to drive less efficiently, climate might require the fan to be used a lot, etc
I can almost buy most of these arguments, but not quite... Maybe it's just because I'm coming from a skeptical point of view.
The heat aiding vaporization probably works in a physics classroom, but this weekend, why don't you go for a drive, then open your hood and put your hand on your intake manifold or the side of your cylinder head when you stop. I'm going to go out on a limb and say those parts will be too hot to touch (the head especially). They add enough heat to the air to vaporize the fuel and then some by the time the fuel hits the back of the valves, and if there is any unvaporized fuel at that point, the valves will be hot enough to finish the job for sure. An extra 30 degrees of IAT isn't going to make or break that equation, especially on an engine with throttle body injection where the fuel has a relatively long time to vaporize before it enters the CC.
Recycling heat energy? The percentage of heat energy in the intake air compared to what the engine producing is probably to infinitesimal to measure.
Lower barometric pressure? Nope, that's a zero sum equation as far as I can tell. Keep in mind that the air pressure is lower on both sides of the engine (intake and exhaust that is), so any differences in the amount of energy necessary to pull the air in would be nullified by the lower amount of energy needed to force the air back out.
The only thing I can say about this one is that less dense air will reduce your dynamic compression. That'll translate to lower FE every time I think.
Is anybody on this forum a pilot? I'm guessing that pilots can teach us a thing or two about altitude and FE....
