theholycow |
10-27-2008 09:11 AM |
Originally Posted by 1993CivicVX
(Post 122547)
It didn't bounce or anything--stuck at 550rpm. So to me this indicates the heat generated going up the hill meant the catalytic converter was hot from going up the hill so the idle didn't need to warm it up.
Thanks for the data. :)
I was thinking about this a few days ago and realized that it can't be about the cat, but I no longer remember why. :(
Originally Posted by dkjones96
(Post 122571)
You are assuming that there is a temperature sensor in the cat so the ECU would know it didn't have to idle up to keep up the temperature.
My VW has one. I used to watch it when I had the VW-specific OBD cable and software.
Honestly, with a heat shield and everything I don't see the cat really cooling down THAT much.
It varies by HUGE amounts, and changes very fast.
Plus, emissions tests never test high speed neutral coasting emissions so I don't see them putting something like that in.
:thumbup: Very good point. They engineer to the test, not necessarily about real-world emissions, and especially not under weird driving behaviors like we do.
Most likely the fast idle at speed is to keep the hydraulic pump in the auto trans going and they just use the same engine management code for the manual trans engine management. It could also be that the same exact ECU is used for auto and manual versions of the car
:thumbup: That's the most plausible theory, IMO. They wouldn't necessarily design it with neutral coasting in mind (or maybe they would, in case it's being towed, engine on, drive wheels down). I'm not sure that it would manifest exactly the way it's been described, but it could.
