Air Pressure
So, the manual and the door sticker say my tyres should be at 29lbs.
The people who mantain and rotate them, America's Tire Store, tell me their experience is that truck tires handle 35lbs best. Why? & Why? |
There is more than you'll ever want to read about it my tire pressure thread, linked in my sig.
What model is it, what is its curb weight, and what size tires are on it? Auto manufacturers recommend the minimum pressure required to avoid lawsuits, in order to sell vehicles to people who like a smooth ride. From https://www.gassavers.org/showpost.ph...01&postcount=4 : Quote:
You should do your own experiments. For FE, the best pressure is usually the highest pressure that doesn't exceed the tire's maximum, doesn't cause ill handling or uncomfortable ride, and doesn't cause uneven wear. For best handling, one generally finds even higher pressure than that is helpful (hence why autocross racers and police cars run often far higher pressures, sometimes even beyond the tire's rated maximum). In my pickup, I run 80 front (tire's maximum rating) and 72 rear. GMC recommends 35 all around. I have been doing it for ~125,000 miles, worn out lots of tires, and have not had center wear yet. In my VW I run 51psi (tire's max). |
Except mine is Gold (actually, they call it 'sand') and my shell is the color of the truck in the picture...
This is the vehicle: https://www.bigsteel.ca/images/gallery/st-57820007.jpg |
My dad's got a 20002 Tundra, no cap. He gets lots of center wear on his rear tires and edge wear on his fronts, which I assume is from hard driving. IIRC he has 265/70R16 tires. The truck is a little lighter than mine (although the cap partially makes up for it) and the suspension is stiffer, so the 70-80psi I run would probably be too much for you.
You probably have P-metric tires on rated for a maximum 44psi, and going all the way up to 44 should work out fine for you. You might want to do it incrementally to be sure you will be comfortable with it, or you might want to go straight up to 44 so you can be sure to notice if it affects your handling. Also, those factory TRD-package wheel flares really protrude a lot, but removing them leaves ugly holes which would then need to be covered with some kind of trim (I think the non-TRD models had a chrome trim that was flat). They might be necessary for the 265 tires not to stick out, I don't remember. |
