Laws about coasting
We often discuss neutral coasting and engine-off coasting, and often accompany such discussion with the disclaimer that it is probably illegal. So, I figure...why not make a thread listing the laws about it?
These are only laws that explicitly prohibit coasting or explicitly require staying in gear. Other laws could be used against you but would be subject to interpretation. Rhode Island: https://www.rilin.state.ri.us/statute...22/31-22-6.HTM Quote:
Massachusetts: https://www.mass.gov/legis/laws/mgl/gl-90-toc.htm I could not find anything explicitly requiring the car to remain in gear or disallowing coasting in neutral. Connecticut: https://www.cga.ct.gov/2005/pub/Title14.htm?dmvPNavCtr=|#39798 https://www.cga.ct.gov/2005/pub/Chap248.htm Quote:
Well, that covers my commute. Search tips: First, google for your state's motor vehicle code. Then use part of the motor vehicle code URL (using google's "site:" or "inurl:" operators) from that to search for terms like neutral, coasting, gear, or clutch. That was easy with RI and MA, but CT's URL changes a lot from the MVC's index to the actual laws. I'm not sure how to search for laws about EOC. |
Fortunately for my 69 SAAB, both the traditional clutch and the gears remain engaged while the overrun pawls of the freewheel between the clutch and input shaft allow the car to roll much faster than the idling engine turns the clutch.
And the freewheel is an emission reducing device, or so it claims in the owner's manual, so I can't defeat it except to push start if needed. |
Commonwealth of Virginia:
Plymouth had freewheeling in the 1930s. I believe you could not engage or disengage it unless you were stopped.
If you forgot to disengage it and went down a mountain road, you brakes would give out and you would go off the side of a cliff. I am fairly sure that is why VA made it illegal. Of course with todays brakes it probably would not be a problem. regards gary |
Looks like coasting is legal in NC if I'm wrong it's because I got tired of scrolling since there is no mention of the word "coast or coasting" in the vehicle law
hope its legal in ontario, because i'm not going to stop:)
besides i'd like to see them prove it. |
I don't think they could ever prove it- unless a runaway vehicle down a mountain caused an accident and it ended up having a manual transmission. Then they could say that a no-coasting law was violated and assign fault.
-Bob C. |
