Stick the right controls on there and you could have an active suspension! :)
Remove some of the leafs and install air shocks?
regards gary |
That's what some of the Audis use and they can adjust height, right?
My 1987 Cadillac had air shocks and an automatic leveling system. Well, by the time I had it, all that was left was empty air shocks. I installed schraeder valves, mounted in the wheelwells so I could open the trunk and pump them up. I emptied a can of fix-a-flat into them then went to the gas station to use their compressor. There, I pumped in enough air for a little bit of rake. I drove out, went over the bump to enter the road, the shocks went "pop"...and I left behind a puddle of fix-a-flat.
Anyway, there's an endless array of products for adjusting the height of full size pickups, including loads of air bags and such, but they're all very expensive. |
Thanks for the info! Had me scratching my head looking for a deeper reason!
I don't know if lowering will help enough for you to detect it. I lowered my car about 2" and if you didn't know the date I did it, you'd never be able to detect it in the gaslogs.
I'd be more inclined to think a tonneau/cap and/or airdam would be more fruitful, not to mention easier and cheaper. |
Well, it could be more useful in a full size pickup with those big axles catching wind than in a car where all you're doing is bringing the flat bottom closer to the ground.
https://dieseldock.com/images_articles/55_binder12.jpg |
Yah, could be.
A deflector forcing the air smoothly under the axle could have a lot of the same result.
