-   -   things I've discovered (https://www.fuelly.com/forums/f10/things-ive-discovered-11178.html)
Philip1 04-26-2009 05:03 PM
I have figured out a few things that improve an engine's efficiency.
1. proper size inlet and exhaust... Believe it or not the right parts improve milage. Example: 1983 Datsun Maxima 27mpg stock add cone filter and 2.25 inch exhaust and milage was 32mpg. I may be told I'm nuts but I have seen this on many of my vehicles including my current car.
2. proper ignition timing... often vehicles with a distributer ignition are set incorrectly. too much advance will ping and make heat too little will waste fuel by not using it for movement.
3. Compression... again this is old school stuff but more compression means more bang goes to moving the piston. take an 8.3:1 compression OHV 4 cyl and bump that to 10:1 not only will there be more torque available because of the bang getting used better but the burn of the fuel will be more complete.
4. proper brake adjustment... often this is something people overlook and a dragging brake will cost lots of MPGs.
I am no expert I don't claim to be one but I like to share my experience if it will help
kamesama980 04-28-2009 08:00 PM
engines 101... no offense but why does there need to be another thread about the absolute basics?
hi tech hillbilly 05-07-2009 08:51 PM
because not everyone on the internets are mechanically inclined or educated.
VetteOwner 05-07-2009 11:32 PM
some of those (the last 2) are kinda set in stone on a properly workign car.
like my chevette brakes (as with all other chevettes) drag especially on the front(very bad braking system,#1 complaint)
compression well thats kinda set in stone without major costly machineing.
i prolly need to at least check my timing again...
