Some diffs fall apart with no axles in, so you have to put a keeper in there to make sure nothing falls out of line if the car gets a knock. Basically a clean bit of broomhandle or something. However, if you pull one straight out, and put the new one stright in, you shouldn't really need to do that, only if you're expecting to do other stuff while the axle is out.
The only real difficulty I had (92 Accord, FWIW) was getting the @#$%$% axle nuts off. If you're using a breaker bar, get a 1" setup. A 3/4" bar can and will shear and break. (Trust me, I know! I wound up buying a compressor and gun - 5 seconds of buzz and and they were off!) If you know someone with an air gun, have them 'crack' the nut for you. You can then hand tighten with your breaker bar and drive home to do the work.
While you're in there, you might want to change the drive shaft seal(s). They're easy to pop out with a seal pulling tool. Pressing them in evenly is a bit trickier, but is also easy with the right equipment. Don't try to 'chase' it around with a small hammer - you need to press evenly, or it will just bind up. I found a short piece of electrical conduit fixture (essentially a short bit of pipe) at the hardware store that nicely fits over the metal outer ring of the seal. Light hammer taps seated the seal perfectly. |
Yeah, that would probably more apply to hondas. The oval hole is what get's 'em stuck in non-circlip apps, when they're forced in, or not even sitting in very well but with the axles sprung against them, then as the diff gets hot and expands, they seat themselves rather solidly.
DONE! I swapped the axle on Friday night. The only issues I ran into were:
1. The Haynes manual stated that you should remove the front stabilizer bar from the lower control arm. Unfortunately, you can't do this and re-use the ball joints, so I just removed the lower ball joint from the hub to the lower control arm. That did the trick so I could get the axle out. 2. When I tried to pull the axle out of the tranny, it first broke apart at the inner CV joint. Then, I had to pry the axle out of the tranny. 3. I still hate changing the transmission fluid on Hondas. The filler neck is a B!@#$ to get to, even with a fluid pump. Thanks for your help, everybody! |
I had one of those, too. The only problem is that when the bottle is nearly empty, it tends to siphon fluid back out of the tranny.
On the other hand, the fluid pump cannot get the last 1/4 quart of tranny fluid out of the container. So what I did is attach the valve to the fluid bottle and held it upside down. I attached the other end of the valve to the pump. When the bottle was nearly empty, I poked a hole in the bottom for air so it wouldn't siphon the fluid back out of the tranny. |
