A Dirty Jobs episode was at an used tire plant. Some were shipped to other countries where it is legal to retread or regroove them. Some are trashed. Most are burned at a cement plant for heat and power. The unburned residue is used as clinker in the cement. As to the OP, I figure drivers who take turns fast, and don't identify as hypermilers likely have other driving behavours that are unfriendly to tire wear and gas consumption. I also count anyone going beyond taking it easy on the pedal to save gas a hypermiler. Maybe not with the capitol H, but still a hypermiler. |
Do they even still use tires in playgrownds anymore? I remember I was like the last generation in my area to have a wood-and tire aspestos filled playground. They got got rid of all the wood and tires one year before I left elementary school.
Depends on your region, but I know there are all these people in arizona with those "earth ship" houses where they pack old tires full of dirt for isolation. I watched a documentary on it, looked pretty cool. Anyone doing that could take the tires off your hands, and it would help them build a more efficient home, so you'd be making them work for the environment even when they are "trash" https://www.earthship.net/ Quote:
The number of things you're NOT allowed to do with tires here is annoying, like those earthship houses, no way to get 'em through building codes, can't use old tires for landscaping either, or boat fenders...
Seriously, you can't use them for boat fenders? What possible reason could there be for that? They seem perfect for the job.
Have we calculated the environmental benefits of LRR tires vs. hard compound tires that take a long time to wear down??? I mean I can sort of see the benefit of LRR tires but if we're inflating our tires to sidewall already, shouldn't one of the benefits of an LRR be significantly reduced? The only things I heard that LRR tires have are less tire flex, less aggressive tread pattern and less tread squirm but wear quicker.
So I have to wonder which tire is overall better for the environment; the one having a "nicer" tread pattern (one of the benefits of LRR) and therefore better fuel economy but wears out quicker or the tire with an aggressive tread pattern but worse fuel economy and takes longer to wear down? How much CO2 and other pollutants are outputted from the production of a tire? |
I was under the impression that LRR tires used a harder compound, while performance, and other sticky tires, used softer. Quicker wear would seem to imply more friction between the tire and road.
Goodyear Assurance Fuel Max tires have a 65k mile treadlife warranty. Michelin's gas saver tire didn't have a treadlife warranty, but neither do their regular all season tires. Without standardized labeling, we are at the mercy of the manufacturer, and what little independent testing is done, as to what is a LRR tire. Some are advertised as saving gas. Others not so advertised come back as LRR after testing. After about 6 years, you have to worry about tires failing do to oxidation of the rubber. If you are concerned about pollution of tire production and disposal, get tires that will last that long for your use. Preferably a LRR model. |
