Coil for 1&4 measured 5,800 ohms on the secondary and 0.7 ohms primary... 2&3 measured 5,900 ohms secondary and 0.7 ohms primary. I was hoping that is what is was... Apparently not. Any ideas? |
clean all the connections maybe?
change out the plugs and wires (though I think you already did recently) dang-it, the mystery continues |
I got a CEL earlier. P0420
After doing some research, I think the code is being thrown because of an exhaust leak. I can rev the engine and when it is going back to idle, I can hear the "pop, pop,pop" of it sucking air. I have a feeling it is at the flex pipe. I'm letting the car cool off before I crawl under it to look. Correct me if I am wrong, but this would cause the symptoms I am having. |
exhaust may be a good place to start. here is some info from the obd web site.
https://www.obd-codes.com/p0420 |
I found the leak. It was at the flex pipe like I thought it was. Next payday, I'm gonna have a new one welded in. Hopfully that fixes it. If not, I will go from there. Thanks for your help everyone. |
