Found another air filter test, some exhaust discussion, etc
https://www.autospeed.co.nz/cms/A_111486/article.html
This one sets out to prove that a drop-in high-performance filter element (K&N, etc) does not affect power in the OEM air box. Surprising results take it further, showing that an old dirty filter is no worse than a new filter, and that entirely removing the filter is barely any different from even the dirty filter. They use a pressure gauge to measure on both sides of the filter... Quote:
https://www.autospeed.com/A_111109/hD...s/article.html A good idea is presented: Rather than spend big bucks on aftermarket high-performance stuff, you might try getting OEM stuff from a more powerful vehicle, which you may get cheaply or free. Interesting FE projects, some of which have been posted before: https://www.autospeed.co.nz/cms/A_111509/article.html - Air conditioner controller, not much use for us here as presented but easily modified for different inputs - DIY oxygen (O2) sensor/Air Fuel Ratio (AFR) monitors for narrowband and wideband - "FuelSmart" which is claimed to (approximately) show BSFC so you'll know if you're being too light on the throttle DIY AFR meter in more detail: https://www.autospeed.co.nz/A_0217/cms/article.html DIY Open/Closed Loop monitor: https://www.autospeed.co.nz/cms/A_171...popularArticle Every time I look at that site, I find more and more interesting stuff. |
Nice find!!!
They do have some interesting stuff in their site. |
More DIY O2 sensor monitoring...
Narrowband: https://www.autospeed.co.nz/cms/A_110624/article.html Wideband: https://www.autospeed.co.nz/cms/A_110625/article.html |
