Ever heard of P07-N01 ???
I've finally got all the bits to run my JDM VTEC-E; stock exhaust manifold & cat. with 5 wire 02 sensor, plus EGR valve and control box, and a P07-N01 ECU. I've looked all over the web but can't seem to find the P07-N01, P07-everything else but not N01. Anyone have any knowledge about it?:confused:
Thanks |
Re: Ever heard of P07-N01 ???
IIRC it is the version of the ECU available in the other parts of the world that run the VTEC-E such as the D15Z7 in Europe. But this is going off of memory from one other user (that I can't find the PM from) that had an N01 P07 ECU. I do remember that he was not located in the U.S. though.
Correction: Honda ECU label Decode N01 usually denotes a factory reprogram, no particular market. So it should work just fine. |
