evans performance |
07-15-2011 03:31 PM |
Re: Cx P05 ecu fed vs california
Originally Posted by *************
(Post 161247)
Well maybe you could do everyone a favor and get a hondata chip installed in one so you could tell us the difference. The CX engines are the LEAST popular engines and so it's highly unlikely anyone has gone to any measures to figure out such information. Get a Hondata chip installed in a CX california and a federal ECU and compare the fuel tables.. This will not work for the VX because I know for certain the VX ECU is very unique and Hondata is not designed for it.
please stop spreading mis-information. there is so much of it on the internet already.
any honda obd1 ecu can be chipped and tuned in the exact same manner. there is no website with fuel table information and getting any form of hondata cant show you what is on the ecu stock. even if it could you wouldnt be able to know much about what is in the fuel map by looking at it. all of the tuning programs use numbers in their fuel tables, BUT they dont mean anything. its just a number so you can see that you are making changes and you can see that other cells are higher/lower than the ones next to them.
swapping a cx ecu into your vx or vice versa wont get you what you are after. if you want better gas milage, get a cheap(ebay) cold air intake and header, then find a local tuner to chip your ecu and tune it. you could easily be hitting 40+mpg on the highway.
