Re: grill blocks
just installed my home made grill blocker today!! let you guys know the result. my air flow is not compromised though because there is a lower grill that lets plenty of air flow in.
Re: grill blocks
Re: grill blocks
free lol found the plexiglass and rubber hose at our shop.
Re: grill blocks
grsshpr1,
if your aerodynamics is like that of the cavalier, then about 90% of your cooling comes from underneath. on my car there is a flap that attaches to the bottom of the radiator that directs air towards the radiator while going down the road. I know the old 90's camaro was the same way. if the flap gets knocked off, you start to run hot. I have my entire lower grill blocked off. I used to have the opening between my hood and bumper blocked off all but enough room to pop the hood up. I was just lazy on that and didn't put it back on. I have had my lower grill blocked off for over 3 years. about 1.5 to 2 years ago I permanently sealed it off. I will admit that my body work skills are horrible but it got the job done and looked good for a little while https://www.gassavers.org/garage_imag...fzq4ynuh1i.jpg I would say to research the crap out of your vehicle before doing it but many of us do have complete grill blocks and though I don't see many 100 degree days, we have seen a record number of upper 90 degree days this year. no problems yet. 14 yrs old and 218k miles (7 yrs and about 125k are from me personally). I started with plexi glass too. made a paper template and used a dremel to cut the plexi. put it on with wing nuts, bolts, and fender washers. if you have some time to kill, here is how I did the bumper when I made it permanent.https://www.youtube.com/watch?v=4n6iNOxl5PA ****edit***** I wouldn't mind seeing pictures of what you did too. curious of how you blocked off the top. always good to see how others do things. |
Re: grill blocks
i'm unsure of how to upload pics onto here? but i came across a shelby cobra carbon fiber front air splitter and i'm going to apply that to my car soon. i'm still getting the parts together for my exhaust.
Re: grill blocks
what I do is go to www.tinypic.com and upload it there (you don't have to join). chose the size you want it first and then do the download. once it is done, it will give you a few options.
the screen says "share this image" at the top of it. the second option is: IMG Code for Forums & Message Boards if you copy and paste this line of text (should say IMG at the front and /IMG at the end) into your message, the picture will show up in the thread. where I work, they block photobucket so tinypic is golden for me. there are other picture hosting sites but this is what I use. |
Re: grill blocks
oh ok so i can use photobucket too i'll get a pic up soon then
