weird.
I thought I fixed
weird.
I thought I fixed that bug. I'll get on it right now. |
I had to disable the gaslog
I had to disable the gaslog for a while as it exposed a rather big bug. Look for it back later tonight.
Re: I had to disable the gaslog
I found a few more bugs as well, but the critical one was fixed. |
it looks good!
it looks good!
Does look good, I suggest
Does look good, I suggest that you allow people to create two different logs (or more) for different cars. No need to explain why I don't think. :-)
Re: Does look good, I suggest
GasLog average calculation
Hey it looks like the mpg displayed next to the car in the avatar window is the average of the mpg calculations where the average is the sum of the mpg divided by the number of entries. This is not accurate because a high mpg reading with 1 gallon of gas offsets the low reading with 10 gallons of gas with the same weight. You need to add all the miles driven and divide by the total of the gas used to calculate the mpg.
Re: GasLog average calculation
