Incorrect MPG calc and mileage
Hi all
First post :D I have had a problem since the update with mileages not showing correctly and therefore MPG being calculated wrong, I've checked what I've entered and I'm correct but the system has worked it out wrong. On my log book it's entries 32, 31 and 22. Help! Cheers Adam |
2 Attachment(s)
What do you believe is wrong about the entries? Below are your totals on Old and New Fuelly. The fuelups you pointed out appear to be the same on both.
Old / New Attachment 1605 Attachment 1606 |
In that case old is wrong as well. I didn't do 1154 miles between fill-ups and I've checked the mileages I've entered and the difference between them is not 1154 miles.
I'm confused :-S |
So looking at your Fuel log: https://www.fuelly.com/car/renault/la...boy/232828/log I've discovered a few questionable entries that may need some review on your side. Apr 11 2014 61,548 Odometer Apr 19 2014 65,731 Odometer Apr 5 2014 64,577 Odometer As you can see April 5th's Odometer reading falls between that entered on April 11th and April 19th. Either the dates or the odometer were swapped. Please correct and that should resolve your discrepancies. As for fuel-up #22 (Feb 14th) I'm not sure what the problem with that one is. Can you explain the issue? |
