tasdrouille |
06-06-2008 08:35 AM |
I own an early 99 TDI.
Originally Posted by rh77
(Post 4286)
1. It requires diesel-spec synthetic oil
Which is not more expensive than a good synthetic you'd put in a gasser. Granted you'll have to change it a bit sooner than you would on a gasser, but it's not impossible to go on pretty impressive drain intervals.
2. The timing belt needs changed every 60,000 miles
There are 100k kits available to mk4 TDIs.
3. Consumer Reports rates it in the pooper for reliability
They can say whatever they want, but it never let me down. Sure they have some problems, but it's really just little annoyances. In my car I've had problems with poor lightbulb contacts, the handbrake switch, the cruise control switch, the wipers grease jamming up in the cold and the door latch jamming in the cold too. But nothing that contact cleaner and a generous dose of various lubes wasn't able to resolve.
The powertrain is rock solid. The car can take a lot of beating. Neglect no, but beating yes.
4. If you live in areas with harsh Winters, you have to add an anti-gel fluid to the fuel, and an engine block heater is almost mandatory.
I live in Quebec City and never plugged the TDI once this past winter (because I couldn't). It always started instantly after a good glow plug cycle.
If you live someplace where it gets cold enough for the fuel to gel, chances are there will be all the additives needed in the fuel. At least in the province of Quebec. I've never had my fuel gel in any diesel I've driven since I started driving.
5. It's not a Honda/Acura
Nope, it's more fun to drive ;)
