Vtec is a pain I guess, but
Vtec is a pain I guess, but not really. He wants 75 for a full swap, but I'm buying the dizzy off him for 20, he'd prolly sell the head for 20 plus like 20 to ship it, I'll talk to him about it.
<A href=https://honda-tech.com/zerothread?id=554053 target=_blank>Mini-Me</a> CT he is at. |
swapping the z1 head on your
swapping the z1 head on your current engine could cause some problems. Not only is the z1 a 1.5L engine, but the rods and pistons are different than your engine. Your compression ratio would be much higher than you are at now, which could cause you to have to use 91 octane (or higher).
If you're interested in this swap, I'd recommend getting a brand new engine. It's exactly what I'm doing on my car. My car, however, is a 89, so I have to do fun things like switch to obd1 and MPFI. SVOBoy, since he has a 4 wire o2 sensor, isn't it much better than the single wire we're cursed with? How much different is a 5 wire from a 4 wire? |
Quote:swapping the z1 head
1 wire: 02 sensor gets heated by exhaust gasses and sucks 4 wire: 02 sensor heats itself, and does so more quickly, but still sucks 5 wire: 02 sensor that heats itself and also gives accurate output. 1 and 4 wire o2s, narrowbands, they're called, only measure somewhat accurately around 14.7:1 afrs, the rest is just junk. To a narrowband 10:1 is the same as 13:1, they have no clue. However, widebands, 5 wire, have linear measurments so that all the afrs are accurate;y distinguishable. I'll make a post in the general area about the differences with graphs and ****. |
Re: Quote:It all started in 1985
W00t, I just talked to my
W00t, I just talked to my friend in sweden and he's gonna get me the shadow whatev that's like a third the way down on <a href=https://www.archee.com/GAUGE-HOME.htm target=_blank>this page.</a>
Local
Sweet, your close to me, I live in Prospect, butler county :)
How close is that to
How close is that to phillizzle?
That means there are 3
That means there are 3 pittsburghers on this board. I live in clairton and go to school at california, pa.
Ya'll should have the first
Ya'll should have the first gassavers.org meet up and go egg some hummers or something.
Re: Ya'll should have the first
How about you throw the CX tranny into Rex's hatch, drive to Wexford, PA and along with Kickflipjr and Danno, we can install it into the del sol camino? I'll even pay for the gas for the philshizzle round trip and put you up for the night if need be. ;-) And maybe Diamond Larry can make the trip from Indiana. It's only 6.5 hours. And whomever else wants to join us. There is a Hummer Dealership nearby so I will stock up on eggs. :-) |
