discrepancy between fuelly calculation and mine?
I was wondering if anyone could figure out what I might be doing wrong...
between my last two readings, Fuelly has calculated my MPG consumption to be around 25mpg whereas a "manual" calculation on my part figures it to be just over 30mpg. Here are the figures: my second to last reading was 3,981 km last reading was 4,355 km therefore, 374 km driven... fill up at that last reading was 34.35 litres MPG should be 30.68 mpg or 9.18 L/100 km FUELLY shows 35.61 mpg! Actually, when I switch my preferences to L/100 km for Fuelly's calculations, it seems to match mine (9.2 L/100 km). Is it possible that the site doesn't do the correct conversion? Paul |
What do you have your Viewing Units set to?
Ok, I've finally realized that the issue is the difference between US gallons vs imperial gallons (I live in Canada).. and by the way, I made a mistake in my first post regarding the calculations from Fuelly.com:
FUELLY shows 35.61 mpg! should read: FUELLY shows 25.61 mpg! Thanks for your feedback |
