Importing database and issues on ios and web
Hello,
Due to reasons i lost my gas cubby. Fortunately i was able to recover the last sync from my iphone and import in anew on my ipad. But i can't link the account. I do not receive the confirmation email in yahoo, i've changed it in gmail, but it is the same. No email. I've checked if there are filters, and even added the Fuelly email in the trust list. But still nothing. Also when i've imported the DB it messed up. It shows the prizes in USD instead of BGN as previously. And costs are totally messed up. I'll try to manually refresh my information. But it is unfortunate since i had everything about my car in, and i can't use it properly now. Is there anything that can be done. |
the email, finally came through, but i noticed another thing. the odometer is also messed up first fill up is around 118 000 ish
but it shows up as 180 000ish |
ignore this, i've fixed it. i had to change the measurement units prior to recovering the DB file.
buuut, the verification email from the app is still nowhere to be found so i still can't sync the app to the fuelly web page, so i can move to the new app |
Are you using Gas Cubby or Gas Tracker?
The reason I ask is this thread is in the Gas Tracker forum, but from what you describe, it sounds very much like you're using Gas Cubby. |
What verification email are you waiting on? |
my car is at 119 000 ish km but the data shows as 190 000ish the prize per litre is around 2.60 BGN (1.80 ish $) but it shows as 0.0025 something i managed to fix the odometer statistics but everything else is still of the charts and there is no option for them to be swapped. there is from metric to imperial and around but not for the currency and the volume |
