The carbs are at the back with no cold air feed, so the effect from driving at higher speeds shouldn't be as great as some. Also, They are automatic flat slide carbs. They work by the vacuum from the engine, so they will only dose what the engine can use. I can put my foot to the floor at 2krpm and it won't throw in a ton of fuel because the draw just isn't there.
I'm not concerned about comparing with other's, i am a member of a club which probably has the only other people with a car anywhere near the same, so i have their experiences to go with. But it'd be nice to have a site where i can log all my fill-ups and mileage, and get a good picture of what's going on. I'd like to say my driving is consistent but it isn't (i have a couple of trackdays this year but i won't include them), so anything that'd show this would be good too. |
If you want accurate results, your driving doesn't necessarily have to be consistent, but your filling methods do. As for the track days, you won't really be able to track fuel usage as no doubt you'll only want to use a small amount of fuel in the tank for weight and safety reasons etc. Fuelly needs a full tank so it knows how much you've used.
My concern was with a non-stock car throwing off the data of the stock ones in Fuelly's database.
It's got a terrible filler neck. It's in line with the top of the tyre and they're 13in wheels..
I brimmed it the other day from red and got 39 quid in it. I brimmed it again yesterday and got 45 quid with a little more patience. But it's only a small light car, i don't like carrying a full tank. At the moment i'm just logging the miles and litres whenever i fill up, which will be relatively little and often. Then i can add a side note of the general type of driving. On bank holiday monday i drove to St.Helens and back (i live in Milton Keynes). This took about eight hours! The traffic was horrendous, half the journey on the M6 was spent crawling in 1st gear.. It was a wasted opportunity to test an economy run. Incidentally, i've now done 400 miles on that £45 fill but it's in the red, so i suppose about 40mpg - never travel on a bank holiday if you want to save fuel! |
SO... when you filled up the first time, use the 366 along with the rest of the data you input... AND MOVE ON. |
Closing this thread. OP has indeed moved on. Last fuel up and login to the site was a year ago.
