with the right timing and
with the right timing and premium a car that used to run on regular can gain some power.
But why would you advance
But why would you advance timing for boost?
Re: I wouldn't want to reveal my
Also, using premium fuel should have NO effect on your compression readings. |
then is why my compression
then is why my compression going up?
my gas purchase is based on credit card rewards. my favorite is shell, so that is what i use most. prices are no issue in my area. they all are very competitive except for sam's and race track, and i won't buy either of those!
incidently, i tested most of the gas in my area, and have concluded that shell gives the best value(mpg yield). sadly, chevron, i thought was better, but both stations near me closed. |
Hooray for old bumps!
no question. i don't see how premium fuel could contribute to carbon if that was the presumed connection.
is it too late to change my screen name to "bump meister?" |
I wasn't suggesting that premium fuel contributed to carbon buildup, just that carbon buildup might explain the increased compression.
totally w/ ya. my thought was that compaq888 MIGHT be drawing that conclusion.
