View/Sort DB?
My particular need is to be able to track monthly fuel costs, and to do it across platforms, since some of us use Android and some iPhone. Is there a way to view the database and perhaps sort by month, maybe print a monthly report? Even an export would be okay. I've looked around and can't find it. Am I missing it?
Thanks, Tim |
1 Attachment(s)
On your vehicle dashboard, you can add mini stats and track everything, milage, fuel used etc and set custom time parameters too, so if you wanted to see how much you spent in 1 month, you can do such a thing. You also have "cost analysis" Where you determine the time parameter too, I have set mine to 2016, but as you can see, it's all customizable. You can also download csv reports too. Hope this helps.
