the very reason why i never
the very reason why i never use my fan. I even set the themoerstat to "COLD" i notice the water temp rises faster when monitering it with the scangauge.
man i wish i wasent working
man i wish i wasent working so i could read thease faster :P
yes as matt said, i replaced all the lights (even the little ones in the buttons) to leds. i like the "white" light they put out. mor of a blueish-white. evrey bulb in the car except for the headlights are leds. and i'll tell ya i gained bout 2 mpg. total was $135. start with the brake, turn signals, and backuplights to start out with as thease take the most current to run. look here https://www.superbrightleds.com/1157.htm heres what they say about converting: Quote:
White LEDs behind color lenses
So, the site recommended not to use clear LEDs behind red lenses (but use red instead). That doesn't make much sense because the original bulb is clear. What did you use, DieMaster?
RH77 |
saw the website, very
saw the website, very interesting!!
Might have to go this route. The funny thing is at first my headlights are bright but after some driving they get very dim. I think If I change everything to LED they will stay bright and I might still gain 1mpg. |
Re: White LEDs behind color lenses
I have a handful of each LED bulb replacement for my old car (new car is newer style of base on the bulbs for alot of the lights) and I tried a white LED in one side, and red in the other, and the red was brighter for the same manufacure of bulb replacements, also red LED's are much cheaper to produce, so I see no reson to use a more exspensive white LED behind a red lense. |
A red filter will filter everything EXCEPT for red, which means if your light is red to begin with, you have nothing to worry about. |
I noticed these bulbs are on
I noticed these bulbs are on sale at canadian tire
<A HREF="https://www.canadiantire.ca/assortments/product_detail.jsp?PRODUCT%3C%3Eprd_id=84552444328 5172&FOLDER%3C%3EbrowsePath=2534374303517494&FOLDE R%3C%3EbrowsePath=2534374303517495&FOLDER%3C%3Ebro wsePath=1408474396670062&FOLDER%3C%3Efolder_id=140 8474396670062&ASSORTMENT%3C%3East_id=1408474396670 271&bmUID=1143910252341">LED bulb</A> Ive thought about getting some but I dont think my lights are on enough for me to notice a gain. Maybe i'll just do brake lights for now and see if i notice a difference. |
I did some research and LED
I did some research and LED turn signals are a no no on a nissan. Even with the flasher unit. I already had a problem with my turn signals this year I don't want to mess it up. I think I'll just buy the 2 red brake lights and 2 white license lights.
That should save me some power. |
I have some good news and
I have some good news and some bad news
bad news: turn signals won't work even with flasher unit, instrument cluster is full of bulbs, 3rd brake light hard to get to. good news: my AC controls are only lighted up by 2 LED's, I can replace the 2 brake lights and 2 license plate lights with LED's. And I just saved a bunch of money on my car insurance by switching to geico, just kidding, LOL |
Re: I have some good news and
why are led's no in tursignals? mine work just fine. u gota get the led flasher or get a heavy duty flasher so the flasher dosent buzz from the low current. i even hooked up a pot on my flasher so not only do i have leds, i got variable flash rate too :D lol i'm such a geek... lol BTW if your car has the brake light burnd out idiot light just take the bulb out of the cluster :P it sounds stupid but u can allways use the crome bumper if the semi behind u to see of the lights are working :D |
