how to restore backup zip?
I purchsed a car from a fellow GasCubby user and he sent me his backup zip file containing the vehicle profile and all of the fillups on the car since 2012. I have not been able to find a restore/import option that works with this export file. Can someone direct me to where I can import this info?
Cheers! |
Recover data from iPhone
1 Attachment(s)
If you delete or lose data on you iPhone, you can get them back. The most common used way is use iTunes or iCloud as long as you have made backup. But if you don't have backup, don't be upset yet. You can still regain the lost data. In case you need it, below I share the link to solution on how to recover data from iPhone:
How to Recover Data from iPhone without iTunes or iCloud Backup |
The easiest way is for the user you bought the car from to transfer the vehicle to your Fuelly profile.
That user will need to: Select that vehicle in their Fuelly profile. Select Transfer Vehicle Enter your username and transfer. You will need to accept the transfer in your Fuelly mail and the vehicle will appear in your profile and be removed from the seller's. |
There are various solutions on how to restore iPhone data, you can restore iPhone data from iTunes backup or iCloud backup.And you can also recover data from iPhone directly without using backup. iOS data recovery software can scan deep through your iPhone to dig out the lost file from phone memory or SD card.
Form iTunes backup to recover data
