Not to step on any toes here, but a slightly cheaper version of this DIY catch Can can be had at your local auto parts store. I did the exact same thing as SVOboy in principal but spent less. I purchased a FRAM fuel filter #G3 for $4 and placed it in the valve cover vent and the PCV system, like so:
https://www.imagestation.com/picture/...1/ec39b733.jpg https://www.imagestation.com/picture/...c/ec3a2a99.jpg |
Noice!
um that filter looks like it will clog WAAY to quick with oil. other than that, sweet!! i would cut a small hole somewhere to let the pcv system continue to do its job even when clogged, by small hold i mean 1mm diameter.
Yeah, the filter is small in stature but I check it daily. The one that runs from the valve cover to the intake tube has been on for over a week with not even a hint of oil in it. The one that is on the PCV system has about 3 drops of oil in it now and has been on for 4 days. They are easy to pop off and drain when/if they begin to fill up.
The air flow of that fiuel filter will also be less that what you generate with blowby , so you can expect oil leaks from everywhere., and made much worse when that paper element gets soaked in oil , blowby will not pass then at all. PSSSSSSSS - POP Its a sucky idea :thumbdown: |
Well lets give this a shot...!?
There's a 100ml size? I should get that. My small one fills up very quickly and needs to be drained after almost every tank.
mine fills up even before my tank runs out. usually half of it is ice. i have to bring it inside and let it thaw before i can empty it.
a real pain but at least i know its doing its job. https://www.fuelly.com/attachments/fo...82abe286a7.jpg |
My catch can is a an old air filter use on large pneumatic industrial machines. Made out of nylon, lexan and stainless steel mesh, it is rated at 150 psi... not that its going to be seeing any positive pressure in this application. Its 5" tall by 2.5" wide.
https://farm1.static.flickr.com/170/4...29224bdb_o.jpg The bottom half unscrews for easy cleaning. https://farm1.static.flickr.com/181/4...cda54887_o.jpg Installed between the crankcase oil separator and the intake hose. https://farm1.static.flickr.com/159/4...e80433ce_o.jpg I haven't driven it yet but I'll update when I put a few miles on the setup. The best part: It was free :D |
Secure
After a body shop fooled with mine and sucked up the gunk into the intake manifold, I can't stress enough, the importance of securing the catch can to something. tjts1, it looks like you've done it right.
I can see most of us (including myself) having it hang mid-line and use the tightness of the connectors to ensure the proper alignment, but if it's bolted to something, the error of defeating the purpose of the device is minimalized. For me, that would mean additional length of hose. Ensure that PCV hose is used. It can withstand the corrosive liquid, and the suction -- the parts store should know exactly what you're requesting (if not, run!) Outward pressure hoses like fuel lines don't take vacuum into consideration and can collapse under the Vac over time from heat in the engine bay. RH77 |
