Decimal point disabled
Hello,
After upgrading to version 5.0.4, I am unable to input a decimal point for the volume. This is causing me a big problem. Can you correct this issue asap please? Thank you |
Please go to Vehicle Details and make sure that your country is set to the United States. My guess is that your country is set somewhere in the South Pacific.
Indeed, this solved the decimal point issue. However, I am being forced to use another currency.
My country is Mauritius, in the Indian Ocean, near Madagascar and our currency is the MUR, the Mauritian Rupee. Can you please advise how I can correct it myself from the settings, or you need to update the software? Please note that the problem did not exist before I updated, but I do not remember on which last version it worked. Thank you. |
We need to update the app, there are a few countries that do not have access to the decimal.
Please fix this As Soon As Possible!!! I fueled up this morning, and this BUG is destroying my absolute event accuracy for 4 years worth of fill-up records. (Pro App user.)
The workaround until we fix this bug is to go to Vehicle Details and select a different country. The currency will change, but it will not affect the values entered.
