Re: wow... i'm doing it!
Yes, no one like breathing
Yes, no one like breathing poison.
Re: Yes, no one like breathing
I saw the one writeup that had them point it at the ground... and I was thinking, why on earth does this person even have a catch can? They should just run a straight line to the ground. But when I do this tomorrow, I will be sure to run it back into the intake manifold :)I'm just trying to figure out how to do it with my ga16de, since I have two lines coming from the valve cover... one to the intake manifold and one to the intake pipe.. should I plug the one part coming off the valve cover, plug the pipe coming from the intake and run the catch can on the other side or what? https://img191.imageshack.us/img191/3526/pict00065pw.jpg https://img191.imageshack.us/img191/6474/pict00075ul.jpg https://img191.imageshack.us/img191/9328/pict00085tk.jpg https://img191.imageshack.us/img191/6681/pict00093zp.jpg And what is the purpose of that 3rd line? |
the first pic is your pcv.
the first pic is your pcv. It's the little piece with the nissan emblem.
yes I know. Doesn't the
yes I know. Doesn't the other line do the exact same thing (the one that runs to the intake pipe) ? But its worse since it has to travel through the throttle body as well?
800 ? 800: true);"
You only need to do the one
You only need to do the one going to the intake manifold, I think the one going to the arm only carries fumes and not the other crap.
After driving for 40 miles.
After driving for 40 miles. I have a few drops of oil in the can. so it is working.
I am getting alot of oil at
I am getting alot of oil, at the rate i am going i will be able to fill the whole thing in 600miles or so.
