89 Camry
Hi,
I just joined the forum, and am excited to learn what I can and write what I already have learned. I have a 89 Camry with the 2L 4cyl and the 5spd and 128K mi. I am interested in all ways of improving MPG, but know the most about the simple maintainence items and driving technique. My car is epa rated at 26 city and 32 Highway. Completely stock driving efficiently I can get 42-43 MPG at 55 MPH. In the city that drops to 35-38. With the tires inflated to 40 PSI the best I have managed is 45 MPG...but just installed halo plugs and seem to be getting 47-49 MPG. I will write again when I am sure that they are making a significant difference. They are expensive, 9$ per plug. I am contemplating heating the fuel line and a warm air intake at some point as well. -James |
hello,
good stuff. you
hello,
good stuff. you should start logging :) im pretty curious about the halo plugs... seems kinda hokey |
Re: hello,
I'm actually curious to see how Toyotas perform compared to their evil counterpart,the Civics :) Start up a gaslog and get this party started :) |
get some NGK V power spark
get some NGK V power spark plugs, inflate the tires to the maximum sidewall pressure and seafoam the engine. Also try auto-rx, it works really good especially on old engines. You'll see your mileage go up by a couple mpg.
seafoam ruins spark
seafoam ruins spark plugs....so if you put it in your combustion chamber thru the intake manifold...do it prior...
though i dont recommend adding it to the chambers...meaning the fuel tank as well... if you want to clean your injectors...spend the $50-$60 to have it done properly... there are better ways to keeping your chambers clean... catchcans and running efficiently with routine maintenance seafoam in the engine oil is good...it removes a high percentage of residue with about a halfcan installed just prior to consecutive oil changes seafoam compromises oil lubrication ability... do not run it for any length of time 20-60 miles of fairly conservative driving hi |
Will be starting up the gas
Will be starting up the gas log as soon as I fill up next, should be May 3-5. I am actually more of a Honda guy than a Toyota guy. I would love one of those civic vx's, but I was given this car so I will work with what I have. My father has a 06 civic hybrid, so I am going to do a bunch of tests on that(since it has the MPG computer) and write them up and post them here. I am not too impressed with the new hybrids, I can get within 5 MPG of what my dad gets with his civic in the old toyota.
Re: Will be starting up the gas
I'd be careful with the onboard computer on the civic hybrid. They've been known to be a few MPG off. Last night I started dreaming about getting an insight. Maybe I'll do that if the no-debt fairy visits me :P |
this isn't james jeffords is
this isn't james jeffords is it...?
lol thats would be something gotta love a guy who can stir up the whole government ?*?**?***vermonter |
