Re: Well, I'm pretty certain
Wow... you just sent my brain in about 200 different directions with this. this could really work. This would also work as a way to make the rear wheel skirts even more simple. I just need to learn how to weld. |
The actual structure could
The actual structure could probably be torch/solder welded if you used copper tubing or electrical conduit.
But, yeah, getting it welded to the A-arm (or whatever) would need something more solid. You'd probably want a fairly complex framework using 1/2" to 3/4" tubing. My "brainstorm" drawing is with 1.5" - accidentally punched in .75" radius instead of diameter. |
Oh, right - and you'd have
Oh, right - and you'd have to see how it would react over rough terrain. You wouldn't want it crashing into the wheel well when the shocks/struts compress.
Like I said, it would take a fair bit of planning and work, but I think the results would be worth it - both in functionality and in vehicle appearance. |
Did some checking for pipe
Did some checking for pipe and tools - it would be pretty cheap to do. 3/8" pipe would be just fine. A 3/8" or less pipe bender is only $15 in my area, a cutter is $10.
Aluminum tubing would probably be the absolute best - weighs less than a pound for a 12 ft length of 3/8", .050 wall thickness. I think you would only need 8 ft per skirt frame. Not sure about the price of it - $3 a ft maybe? There could be cheaper materials with thinner sidewalls that may work better. |
You don't want to be adding
You don't want to be adding weight to the suspension - the forces involved in a bouncing wheel are very great.
Quote:You don't want to be
Hello -
I posted on this thread : https://www.gassavers.org/showthread.php?t=1539 This thingy : https://www.adcaps.com.au/pages/about.html Question : Why not *extend* the cover beyond the diameter of the rim? Since the wheelwell must accomodate the wheel, it should accomodate a larger wheel cover. For the point of argument, let's say a cover that exposes between 1 and 2 inches of the side of the wheel only. Here is a before/after example of what I mean : https://home.earthlink.net/~cfg83/gas...s_expanded.jpg Problems : Hard to get your hands on these unless you have a taxi driver friend. System may not attach to small rim of Honda Insight. A flat tire would almost invariably SHATTER the (better be plastic!) cover because the current design is "defended" by the real tire rim. Maybe this is an excuse to go with 18" rims (heh heh heh, just kidding, the tires for those things go flat driving over ice cream). This may be a no-show solution, because I still don't know IF the turbulence between the wheel and the ever-so-close wheel cover will be a big negative factor. This does not give you the perfect cover that you want, but I think it is a safer compromise. CarloSW2 |
* might try some air tabs on the leading edge and use the air flow to help hold them in?
* some scrap innertube rubber could be cut in strips in order to get the right tension? ........farm or truck tire place. |
If it was a rear wheel drive car you could make a wheel cover disc with a threaded nut on the inside centre and wind it onto the end of the stub axle.
The hub cap would be able to be within a coupl eof MM of the rim at all times no matter what th esuspension or tyre is doing. Plus its mega cheap to do. Of course with most front drive cars its impossible as the stub axle rotates with drive. PS , I think front drive is doomed for FE. |
