Recalculation on basic stats
I have a MB C240 with plenty (years) of fuelly data. Is a perfect documentatrion about usage hahaha
The question is, in the basic stats the AVG is bad. It shows 8.9 km/liter, but even I never ever did so "low average". Is impossible for having it. Even, If i go to detail average, I never did below 10... Is just a bad "calculation" and I want to recalculate it. Also, for example, in the mobile app, if I enter wrong something.... and after I correct, the average in general is not corrected. Keep the calculation from the first data entry. How can I recalculate the basic stats? Thank you |
You need to go through your record fill ups and see where the error(s) are. Somehow you have not recorded the correct values or entered a partial fillup instead of a full fillup.
Yes, I know, this is the problem. I did a mistake someday, and the average dropds, I correct it but the average doesn't re calculate, keep in the average the calculation with only the FIRST entry.
Example, you add 3 fill ups.... 1: 5 km/lt 2: 6 km/lt 3: 60 km/lt You will have a average about 50 km/lt... and after if you correct the number 3 and put 7 km/lt.... the "average" keep showing 50... (or whatever). I just want to "recalculate" the average in the main page. Quote:
Mines the same it shows 69.9 in the dashboard and 68.9 in my forum badge
If I change to any of the other ie US MPH any will do it displays correctly but when I go back to UK MPG it is again wrong. |
