New Larger Gas Tank
My 2016 Sprinter 4x4 gas tank is 25.5 gallons.
I will soon be replacing the old 25.5-gallon tank with a 48-gallon gas tank. How should I proceed related to Fuelly? Appreciate constructive comments, Will |
I don't know why the size of the gas tank would matter to Fuelly or to MPGs calculated or etc.
Just note the odometer readings at each fill-up and the gallons of fuel used and the MPGs are calculated for you. |
I would fill the 48-gallon tank but subtract 23 gallons from the amount. This would keep the mpg correct if not the fuel added and the mpg is the important value. |
If the trip odometer is being used for Fuelly fills, just ignore the fill up that has the tank swap. No data entry, no messing up of long term stats. You could do a manual calculation if you must know what that one tank's fuel economy was. IIRC, there is a missed fill selection for the odometer method that can be used on the tank with the swap. It resets the odometer zero point for the calculation. That means going through a couple of tanks before getting results, but the results will be for the new tank. |
