Fuel ups gone weird
2 Attachment(s)
Fuelly has broken!
It is not reporting my fuel ups correctly I attach 2 screen shots. One shows my odometer reading at each recent fuel stop The second shows a mix of miles between fuels ups and odometer. Needless to say this screws up mpg completely I have logged out and then back in and same screwed up data remains Can this be fixed? |
You can only use one method of fuel up at a time I believe, otherwise it just confuses the system
Yes, I think it is highly unlikely you did 24,113 miles on a tank of fuel! Delete and re-load that final top-up.
Also, your first fuel up is showing as 300+ MPG which is incorrect too. Chose a method, either odometer or trip reading and stick to it for best results.
Well that was frustrating.
I couldn't get data correct from within app. Tried exporting fuel ups, editing them to correct data and reimporting but bizarrely Fuelly wouldn't even allow import of it's own export file? Bit the bullet and manually re-entered all the fuel ups. Fortunately for this vehicle that wasn't a big number. Hopefully all fixed now. |
