https://www.tirerack.com/ |
https://www.tirerack.com/tires/Spec.j...e1=yes&place=0
An even narrower tire is available, 155-80 R13. It has a diameter of 22.7, as opposed to a 175-70R13. The 155 tire weighs 1 pound less. |
Upping to larger tires is essentially the same as getting a longer geared transmission. The downside of this is that your odomoter/speedometer will be affected as well. Your odometer/speedometer is calibrated to stock tire size, so you might end up being a little off (3% or so) so you might have to adjust your MPG figures each time you calculate them.
Then again, I upgraded to 185s (175 stock) and my speedometer/odometer is right on (I tested with a GPS unit). I would go with LRR tires or more narrow tires before thinking of getting new rims. |
https://www.tirerack.com/tires/Spec.j...l=Potenza+RE92 |
https://www.tirerack.com/tires/Spec.j...e1=yes&place=1
This 155-80R13 tire is only 12 pounds. Neener, neener, neener...... LOL |
