I just got the valve cover off and didn't see anything wrong with the head/valvetrain. I did, however, find pieces of metal wedged in between the timing chain and cam gear and is preventing any valve action.
time for pics
hummm... chain tensioner broke or head gasket material.
i hope hypermiling hasn't ****ed up his saturn. This be a bad case agaist us.
This doesn't sound like hypermiling to me, :p
My dad's timing belt snapped, just happens sometimes. Also, working at the shop for only a month I saw about a half dozen tensioners fail. |
My preliminary examination doesn't suggest that. The head itself seems to be fine. Everything (rocker arms etc.) seems to be snug and in their proper place. I would tend to agree with JanGeo about it being a chain guide. If you saw them you would wonder how they do their job. I did replace them when I did the head swap. Until I get the front cover off I beleive this was due to a random FUBAR incident.:p
I guess you don't have any bent valves or anything then, which is good, :)
My brother says that the timing for the injectors may be screwed up also - not timed with the cam properly would result in gas injection when the valves are closed and causing gas puddles but that would not totally kill the engine - more likely timing slip on the chain/belt or a snapped keyway? I don't know the valve train to know for sure. At least it didn't lockup on you.
