89 Wagovan transmission, what HF will work?
Hello: I am trying to figure out what year or years of HF transmissions I can use to put in my "wagovan". The more I look, the more confused I get. Here is what I've found;
-the diamater and # splines for an 88 is different than an 89. -the Wagovan appears be the same gear box as an SX. Here are some of my questions; -Can I use a 89-91 HF without making any other changes, or will I need to change the flywheel, also. -Is their any way to use a 87 or 88 HF transmission. -Other than the hydraulic clutch, is it possible to use a CX or VX transmission from a 92-95? I know several of you have put HF transmission's in your car's. Does anyone know the answers to these questions, or know of a reference source I can check out, to figure these answers out. Thanks, everyone.:( |
The CX/VX transmission will bolt up, but the hydrolic clutch will be an issue for you. I believe the only difference between the 92-95 and 89-91 transmissions is the throwout bearing. Just use the appropriate one for the transmission you're using and you'll be fine. The best bet is to just find a HF transmission and use your existing axles, etc. I put a WTB ad on honda-tech for you today hoping that someone has one. Since you're in Southern California odds are someone down there has an extra one to spare. |
Totally Awesome!!! Thanks for the information!
Keep in mind that the 92-95 will only bolt to the block - not the frame. That one is a no-go, at least as a bolt-in.
If that's the case I'd say that going 92-95 tranny in a 88-91 is just too much work, especially since you have to convert to hyrdo as well. |
Yeah, best bet is to get an 89-91 HF tranny and use your pre-existing axles.
Thanks for the help. It sounds like I just need to keep my eye out until I find one at a "cheapy" price I feel I can afford. At least being reasonably comfortable about what I need to look for is a great help.
