Tuft testing
In attached airflow, the tufts will stream back relatively smoothly, maybe the ends flicking slightly. In turbulence, tufts will swirl around more dramatically, sometimes in directions apparently at random depending on the severity of the turbulence. Also in attached flow, the tufts will stream in the direction of airflow, often "pointing" towards low pressure areas, particularly near transitions (e.g. rear quarter / "C" pillar area on a 3-box vehicle). Do a google image search and you'll find some examples like this: https://www.tamsoldracecarsite.net/SanteeSSTuftTest.jpg ... showing attached flow ahead of and above the wheel well, and turbulence after the wheel well. (Wheel skirts, anyone?) If you've done any sailing, you're already familiar with applied tuft testing, since "telltales" on the sails are used to trim the sheets and/or change heading to maintain laminar flow on the sail for maximum lift. https://www-gt.diff.net/media/2002_05....thumbnail.jpg . I've spent many hours looking at sail telltales. In this pic, the upper pair (one on each side) shows the top portion of the sail is properly trimmed, and the lower set shows separated flow on the outside of the sail (the outside telltale is pointing straight down), meaning it's stalled or overtrimmed. https://us1.webpublications.com.au/st.../1055_13lo.jpg Tuft testing a Lexus LS 400 - note separation at the forward end of the trunk/boot lid (tuft is lifted in turbulence) and reattached at the trailing edge (tufts streaming back). Tuft testing helps you see airflow, while coastdown & road testing quantifies its effects. |
Cool. I have seen stuff like this from the guy trying to build a new type of valeless pulse jet eingine. He was playing with the coanda effect or something. LINK
It is cool. It's low-tech, but that shouldn't fool anyone into thinking it's not useful, or legitimate.
GM engineers used it in the design of their super-slippery (Cd 0.163) PNGV Precept concept car. You can see the tufts on the model, below: https://www.memagazine.org/backissues.../smooth/75.gif (Source: Mechanical Engineering Magazine - Smooth body ) Edit: the fan's obviously turned off in this picture :) |
Good link too. Tufts in action! (There's a video sample.)
While Googling tuft testing, I found examples of it used everywhere from airplanes, to hurricane-resistant buiding roof design. And now wooden pulsejets! |
Found another good tuft photo:
https://www.aerospaceweb.org/aircraft...f18/f18_46.jpg source: https://www.aerospaceweb.org/question...cs/q0215.shtml |
I suspect that tuft testing is so widely used because there is no real alternative. From the resident authority over at homebuiltairplanes.com:
