Atkinson cycle swap
With all of the engine swaps, has anyone thought of putting an Atkinson cycle engine in their car?
For example, the Toyota Prius head has Atkinson cycle cams and a high expansion ratio. Could it be swapped into a Corolla or a Yaris engine? Likewise, the Ford Escape Hybrid 2.3 l engine has an Atkinson head. Could it be swapped into a Ford Ranger 2.3? What about swapping the whole engine? |
me thinks that the engine swap would require a starter added or you will be bump starting all the time...
You could also try converting the existing engine to an atkinson cycle. It would be tricky depending on the particular application, but a DOHC motor could probably be converted with not much more than a custom or re-ground intake cam. Something tells me it would get more interesting with a SOHC engine since you wouldn't really be able to touch the cam without screwing up the exhaust timing.
If i'm not mistaken, the Corolla uses the Atkinsonized 1.5 that is in the Prius. But I may be mistaken. Did I say that I may be mistaken about that? Someone else might want to check it out.
The Corolla uses a 1.8 liter. No mention of Atkinson cam timing, but its output of 126 HP is probably too high to be Atkinson. It does get great fuel economy, though.
The Prius has a 1.5 liter engine. Maybe the easiest swap would be into a Yaris. It too has a 1.5 liter engine, probably the same block. |
what is this atkinson engine?
We're not kewl enough. Is the insight atkinson? I forget!
Atkinson cycle
This has two effects on efficiency: 1) At low loads where engine efficiency is poor, throttling/pumping losses are reduced. 2) It reduces the compression ratio to prevent knock, while keeping the expansion ratio high. Expansion is where the engine produces power, and anything that increases the expansion ratio improves efficiency. In a dedicated Atkinson engine, the expansion ratio can be increased while keeping the compression ratio low. https://en.wikipedia.org/wiki/Atkinson_cycle I suspect that Toyota and Honda's VVT engines may use Atkinson under some load conditions, simply because their FE is so good. |
hmm.... very interesting...
so how do you time the injectors? |
But only Toyota and Honda and Ford know for sure about each individual engine. I only know enough general info about engines to be dangerous. |
