You'll need either an AC setup(inverters are expensive) or a seperately excited DC motor(affordable home-brew control systems are complicated). Most EV enthusiasts don't even bother. Regen only extends range by 10-15% anyway. |
In an all electric maybe, but I was thinking about using it for deceleration when using the diesel too. So I could grab all that energy that would've gone to the brakes and recharge the batteries with it. Do you have any idea what the efficiency of a seperately excited DC motor is?
You could also stick an alternator or generator on the tail shaft of a normal series wound DC. I've seen that done once or twice.
Hmmm... I wonder if the output is clean enough to charge a NiCD battery? In any event it's something to tinker with. Thanks! :D
reconfigure an alternator for high voltage output to recharge at 36-48 volts and figure on recharging lead bats right after use - nicads not so often but they have a greater charge/discharge energy loss.
