Leg
SVOBoy,
I knew a guy that was putting a shift kit in his C4 tranny and drilled a hole in his leg while drilling out a hole in the valve body separator plate :eek: He was in to big a hurry to go in his shed and use his work bench. Are you two related? |
I used the technique as outlined is this post.
https://www.gassavers.org/showthread.php?t=701 I had to drill small holes in the grill slats but the drywall screws seem to be secure. See the following link for pics. https://servercage.com/wordpress/?cat=7 I cut the hole in front of the radiator ~3.5" x 4". I recently went through some hilly terain in VT and experienced some level of overheating. I had to put the heater on going up the longer hills. I might open it up a bt more but the temps are getting cooler around here. Sean |
Of course I'm kidding. :) |
Haha, go muffler burns. I took off part of my finger print the other day with one, :p
Pictures pretty soon! |
Awful.
Maybe I should have called it the "bro"... or what's the name they used in that Sienfeld episode? |
Manzier.
Looks good.
Thankee. I repainted a tiny part of my trim for practice and it looks lovely. Car will look brand new when I'm done, :p
