I'd recommend eBaying yourself a version 1. Or just buy a SG2 @ $retail and re-sell it once you've had your way with it. You'll likely get 80-90% of your money back. Don't underestimate the benefit you can get from it. If you use it with the honest intention of modifying your technique behind the wheel, it will pay for itself, no question. Quote:
Note: I just split the posts about weight reduction through under-filling the fuel tank to a separate thread:
https://www.gassavers.org/showthread.php?t=1578 |
I belive the run flat tires that come standard on new cars have a plastic donut, and require special wheels, so when your tire blows, it starts riding on the donut that is around the rim, the rest of them are just stronger side walls, also, are t here any narrow or LRR tires out there that are also run flats? I suspect not.
if you want to save even more weight when you remove your spare, replace the electric air compresser with a small hand pump, they take up less space weigh less, cost less and don't require electrical power. |
We could all just get EV 5th wheels and this wouldn't be a problem, :p (I assume it holds some weight!
I thought runflats also include a pressure monitor. That would be a very nice addition to the instrumentation.
Not all of them. I know the H2 has it but my friend's mini cooper doesn't. I also know you can install monitors for like 80 bucks, right matt?
