juddering
Yeah, this has definately been happening in 1-2 shift, and now on bad days on the 2-3 shift on cold starts. It doesn't happen when the car is warm at all. GREAT :mad:
No one's mentioned this so I guess I will. To test your clutch (this is not really good for your clutch, so only do it when you have reasonable evidense that something is wrong)
Get up to 15-20 mph Push in the clutch pedal Put the car in your highest gear Rev the engine to somewhere around the peak torque point Release the clutch pedal, and at the same time, floor the throttle if the engine immediately bogs, your clutch is fine if the engine slowly drops revs to normal, your clutch is on its way out if the engine maintains revs, or revs up, your clutch is gone |
Sure, cars still have synchros...they just aren't promoted, anymore. Too many buyers want the automatics! And...you're not getting gear-grinding noises if you "miss" a shift...those are the dogs you hear. The synchro cones merely match the speed(s) with their slippage friction prior to dog engagement. Oh, "race cars are totally different animals"? Insofar as cluster gears are concerned? Don't you believe it! Ask Hewland.... |
Matt -
I've never had a manual transmission that I couldn't slip out of gear. I never made it a habit, but I could always do it gently (no load on the engine, like everyone else has said). I did it accidently the first time on my VW Karmann Ghia, and nothing happened, so I didn't worry about it. Manual transmissions are GREAT!!!!! If you did have a problem you are well within your minimum warranty. When I had my 2nd Gen CRX, that was the smoothest clutch I ever had. No break-in period at all. Is it the same for the Fit? CarloSW2 |
