But when they blow from a puncture they will really make a big noise much like a high pressure bicycle tire. Probably shread the tire into pieces too! But what the Heck - go out with a big BANG!
Eh, I've had two tires blow out on me after they developed weak spots in the treat that expanded/wore past the rest of the tread, as well as a complete wheel/drum fly off a spindle axle at ~60-70mph. No biggie. ;)
Ha Ha Ha Ha Ha No Biggie!! I Love It!! Badda Booom!
Cheaper than a remote pressure monitoring system. My neighbour drove arond town on a flat for long enough to damage her rim and cause the car to stall - automatic! |
Yeah I saw a girl in the real estate office downstairs drive her car until the tire was completely flat which took several days - left rear which she should have noticed - eventually she destroyed the tire one night when she left work. Ahhhh if only they would be more sociable I would have offered to inflate it for her.
Hi krousdb
You said about excessive tyre wear with overinflation - ?and in my experience, I would respectfully disagree, as would the San Jose police department I would expect.? https://www.officer.com/article/artic...on=19&id=27281 Over-Inflating - Causing rapid wear along the centre of the tread. https://www.national.co.uk/products-tyres.asp Overinflated tyres- # Causes more wear in the centre of the tyre. # Reduces the tyre's grip. https://www.smartdriver.co.nz/Articles/Tyres.htm HIGH TYRE PRESSURES. Over inflation is also highly undesirable with risks from blow out, uneven wear and a harsh ride. https://www.tanvictyres.co.uk/pages/tyre_info/law.htm Over inflation reduces the ability of the tyre to absorb road shocks, resulting in a much harsher ride. In fact, excessive over inflation may lead to impact fracture, or other casing failures. Over inflation will also cause excessive wear of the centre of the tyre https://www.bridgestone.com.au/tyres/...care/facts.asp Over-inflation Over-inflation has resulted in the central tread area being forced into contact with the road causing rapid centre and worn shoulders. https://www.dunloptyres.co.uk/ourTyres/car/tyreCare/ Over-inflation causes tyres to run hard, more vulnerabe to impacts, less grip due to reduced area of contact with the road and faster wear in the center of the tread. https://www.michelin.com.sg/car/car_cat_tips.jsp#16b From these sites that all say that overinflation will result in less grip and more centre tread wear. Ime sure that police article you sited had a good motive behind it but I would rather go with advice from the tyre companies themselves and leave the cops for busing the coke dealers. |
you think 40 psi is dandy? wait till you hit 60 psi, just don't hit that pothole! well I hit ones many times at nasty angles and my tires are still going on their originals! And yes these tires have quite a long history...
i can't wait to start a fresh set, and start from really high pressure from the beggining. I'm sure my tires will last WAY longer than what I had these for. |
Hi krousdb
So , are you saying that these multibillion $ tyre manufactures dont know what they are making , or are they just lying , either way ..you got to do something about this scandle before someone gets hurt. :D PS ,.i hope this overinflation issue isnt about going form 25 to 35psi. 35 is not over inflation , but 60 or more ide consider over inflation. |
Hmm,
I don't see a scandal here. I just pointed out an article and conveyed information about my experiences with overinflation. And after reading through your earlier post, it appears the we actually do agree on the subject. :thumbup: Quote:
