E10 doesn't lower FE in all cars!
And FWIW my car actually appears to be one of them that is happier on E10 than on E0! I just got done doing my second E10/E0 ABA test (i.e. E10 => E0 => E10 ) this summer, and guess what? In both cases, both the FE and the performance went DOWN when I used E0, and back up when I put the E10 in. Now, I don't know how typical this is, but it is clearly not true that every car would benefit from using E0 (and therefore we should avoid gasohol at all opportunities). Instead, since this is a YMMV thing, you should really try it and see which is better for your car (assuming that both are available in your area). As for me, I think I'll stick with the E10, as I get more engine pickup/performance + better FE with it... |
https://www.ethanol.org/documents/ACE...onomyStudy.pdf https://www.greencarcongress.com/2006..._tests_e1.html |
DATA?:D |
i hate the idea that you are forced to buy E10 and in some places E20, not only does it reduce fuel efficiency it cost more energy to create a gallon of ethanol than it is worth through cultivation, harvesting, processing and transportion, not to mention all of the pesticides and fertilizers used. i think E85 isent bad but you should have a choice in buying it.
bottom line Ethanol as a fuel SUCKS!! |
In principle ethanol is great. Don't blame it for an economic systems that is geard up to make any other non gas fuel more expensive. If they used the wast bio-matter to make an alcohol fuel it would be cheap as chips. And as for less FE and power is concerned , raise the engines compresion ratios and that will be restored , or improved on. Base line is ,, its goverment (world govt) policy that makes all alternative fuels unviable and it will continue to be that way untill they work out a way to sell it at greater profit than what they get from gasoline. |
