-   Introduce Yourself - New member Welcome (https://www.fuelly.com/forums/f6/)
-   -   newbie civic owner (https://www.fuelly.com/forums/f6/newbie-civic-owner-2978.html)
EH3 09-20-2006 03:08 AM
newbie civic owner
hello everyone.
i have a 92 civic Si. a little heavier than the CX/VX gas miser counterparts, and much shorter gears.... but a little more daily driver friendly. i'm working on my inital fill up which looks to be around a 45mpg tank. shifting at 3k rpms and cruising at 60mph. we'll see when i fill up next.
my Si has a JDM d15b engine with stock Si tranny and d16z6 ECU. i am going to have the ECU socketed soon, and i will be DIY/wideband tuning with CROME for max efficiency using a combination of JDM d15b and USDM d15b7 fuel/timing maps.
i previously averaged 47.7mpg in my old d16z6 powered CX hatch @ 65mph.
here's my honda-tech garage of past civics:
https://honda-tech.com/garage?cmd=vie...e&id=999307685
EH3 09-20-2006 03:24 AM
see if my signature shows up now
SVOboy 09-20-2006 04:02 AM
Your signature is up! Good to have you here, doing pretty well with such a little peppy car, :p
Ever considered an HF 5th?
EH3 09-20-2006 04:41 AM
i might consider a DX 5th. that's about as long as i'd go. i'll probably just swap in a DX trans altogether, though
this car is FAR from peppy, in fact... i'd say it's completely gutless. i recently sold an H22 powered EK civic that ran a high 13sec 1/4mile. that was peppy.
SVOboy 09-20-2006 06:29 AM
Haha, what's wrong with the HF fifth?
Yes, that seems slightly peppy, you could always just get a full-fledged HF, :p
Matt Timion 09-20-2006 08:08 AM
Will EF gears even fit into a EG transmission? What about a VX 5th?
EH3 09-20-2006 08:36 AM
yes, but i believe it depends on the case size. Si/Ex trannies are "big" bearing, VX/Std/DX/CX/HF/etc are all small bearing.
HF/CX/VX 5th are too long for my liking. at highway speeds FE likely goes down because it takes so much extra pedal pressure to overcome aero resistance. that's why i think DX is best. for low speed (under 60mph) they're fine.
Matt Timion 09-20-2006 09:09 AM
It only takes like 10HP To maintain highway speeds. You could always install a 5th gear as a cruising speed (you'd probably cruise around 1500RPM at 70MPH, compared to the 2500 you're probably doing now). if you need to accelerate, that's what 4th gear is for.
Or just do a DX swap. It's still loads better than the SI tranny.
LincolnW 09-20-2006 01:08 PM
Dang, 47.7mpg while going 65?
I never really go over 60 or so and am in the 36-38 range (90 STD hatch w/ d16z6).
I must suck at FE driving or something.
Matt Timion 09-20-2006 01:36 PM
The EG is MUCH more aerodynamic than the EF, so I'm certain that has something to do with it. I'm certain that other small differences (tire size, LRR-ness of the tires, etc.) account for the rest of the difference.
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
