Rolling Resistance
Does anyone have any info on what bearing friction is compared to rolling friction? I've seen that increasing tire diameter lowers rolling resistance marginally, but I haven't found anything stating why it does that. Since rolling resistance is supposedly caused by both the ground and tire deforming, it follows that a harder compound and more pressure reduce the tire deformation and rolling resistance, but increases in diameter shouldn't do anything between the tire and the road. It will however, result in the bearings spinning less compared to the tire, so if the resistance of the bearings/races is greater than the resistance of the tire/ground, an increase in diameter should minimize this up to a point, and lower the total force the tire has to overcome. Thoughts, doughnuts, skunks? :)
Anyone (who doesn't have sealed bearings, I H8 'em :() try synthetic greases? |
Another thing to concider is the rotational weight. In general when you increase the diameter you end up increasing the weight of the wheel/tire. I don't claim to understand it but this is something that can have a measurable negative effect.
I would think the larger diameter would have atleast 2 (qualitative) effects:
1. the larger diameter tire might mean less angular deflection where the rubber meets the road (sorry ;) ). 2. a larger tire should much more easily roll over the irregularities in the road surface. |
All sounds to me like a good reason to drive slower.
just a little dependant - linear - not exponential like air drag
Hi Silveredwings, aren't No.1 and No.2 the same thing (1=>2), or for that matter, how much does angular defelection depend on tread/pressure? What about the additional weight of a larger wheel/tire?
I had a comment that states that a reduction bearing rotation helps, a little. ;) Quote:
If that was true then Bicycle tires would be small. The bottom has to be flat to match the road so the larger the diameter the less it has to flex to get flat on the road.
But bicycle tires are small. :confused:
26 inch diameter about the size of a car tire is not what I consider small - 10 -12 inches is small.
