So what's the verdict? If I plumb some 3/8" copper tubing from the exhaust pipe to the intake manifold, will I see better mileage?
Probably not since the engineers who set-up your engine already figured the maximum amount of heated exhaust that could be added w/o raising the cylinder temp too much, i.e. egr is probably already optimized for fuel economy, unless you don't have it. You could try it, but make sure to keep an eye on the engine and have a cut-off you can use in the car, detonation is never good for an engine. A nice project would be to take a solid old iron block/head engine, retrofit it for SAFI/EGR, and run methanol. Maybe even a turbo if you're so inclined.
omgwtfbyobbq: are you sure you don't have things backward, re: cylinder temps with EGR present? (And related issues of detonation/octane)
The little reading I've done on EGR says that it lowers combustion temperatures (thus reducing formation of oxides of nitrogen). That would allow you to run both fuel with lower octane and more spark advance than without. Also, I have my doubts that EGR is fully used for FE savings, since as you approach the maximum amount of EG you can have in the cylinder before you cause a "missing" condition, driveability suffers (appearing as hesitation on acceleration). I believe engineers always err on the side of drivability over efficiency. |
A relatively simple & crude way to test this would be to get one of those long exhaust hoses the mechanics use, and set it up to feed exhaust into the intake while driving and monitoring the ScanGauge.
See Octane rating - Measurement methods. |
Um.. Not actually planning any test.
But, pick up what? |
Crap Again
One point -- Xylene was not mentioned. Of all of the additives, it seems to have the least "side effects" on the fuel system (if you add lubrication -- such as "Marvel Mystery Oil"). RH77 "making a note to have citations for future posts" |
If it worked, then you could look at splicing into a pipe in/near the engine compartment, or modding the EGR valve/system itself (though from what I've read, that'll likely cause the ECU to throw codes). |
