Block heater revisited
Does anyone have data or a guess as to the increase in FE with a block heater installed? I searched the old threads and couldn't find anything.:o
I've been looking for one for my 3-series - if I ever get it back from the shop. I'm thinking either a freeze-plug type or a circulating type depending on installation difficulty.
Probably depends on the engine displacement, temp the heater can get the coolant to, outside temp, and trip length. Iirc, the amount of fuel injected on startup is proportional to coolant temp, since this is used by the ECU to guess at how warmed up everything is, so I'm guessing it's pretty significant. I'm also guessing for short trips to the store it could make a huge difference, but for longer highway trips, not nearly as much.
EBH Salesman
I should be an EBH salesman, because I believe it works extraordinaly well in reducing excessive fuel consumption on cold startup.
Just a rough estimate: with the EBH on for a sufficient amount of time to operate at peak temp, the time to closed loop is within 20-30 seconds; whereas, closed loop on a cold start under similar conditions would take up to a minute or more. Say, open-loop idle is 1.5 gph and closed loop is 0.6, then there's the savings. The throttle input should be proportional to gallons-per-hour figure when moving to give you an idea of fuel consumed. I even operate it in the summer to reduce startup wear and quicker C-loop. RH77:thumbup: |
Just as a rough guide to how much heat my heater makes ...when its been on all night the needle is 4MM above the cold line on my Swift (metro).
It doesnt get any hotter than this and isnt engine running warm , but within 1 minute of driving it is at normal opperating temperature. |
I have found on my short 11 mile commute I get about 5 mpg better (according to SG) with a warm engine compared to cold. So I would agree that if you have a lot of short trips the benefit would be more noticeable, for longer trips the FE gain wouldn't be as noticeable, still there, just not as prominent.
And this doesn’t take in to account the added benefit to the engine itself or the operator. |
I'm in agreement: it depends.
If you're doing a lot of short trips with cold soaks in between, it'll be a bigger relative benefit than with fewer, longer trips. This PDF tries to quantify the fuel savings, but you have to take it with a grain of salt (they're selling them). Also, it focuses on the benefits of short trips (because it looks better presented that way): https://www.defa.com/doc/7642.1070613161.whyxdefa.pdf |
